rear seat brackets?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by wrath, Feb 19, 2002.
  1. wrath
    wrath 1/2 ton status
    Mar 4, 2001
    182
    Grayling,Michigan
    Was wondering if anyone could take some pics of their rear seat brackets and how they mount..Picked up a rear seat from a fellow K5er off the ColoradoK5 forum but it doesnt come with the mounting brackets..could someone fill me in on what they look like and how they mount.My '70 didnt come with a rear seat so I'm somewhat clueless.Any input on where I could get these new or used? Thanks for all the help!!
    70K5 350ci.350/205 "PROJECT 40"BOGGERS" It runs and its clean !!
    <a target="_blank" href=http://communities.msn.com/OurMudToys/the70k5blazer.msnw>http://communities.msn.com/OurMudToys/the70k5blazer.msnw</a>
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    don't have any links or pics yet, but front of the rear seat had two clamp like brackets, and rear has 4 or 5 bolts that go thru flat like flanges.
    BTW, anyone have an extra front bracket for the rear seat, (small part) I"m missing one....
    Like em big and topless
    You call THAT...a 4x4....LMAO?
  3. jmeador74
    jmeador74 1/2 ton status
    Oct 31, 2001
    108
    Eatontown, NJ
    I just used conduit clamps and they seem to work pretty good for me... just had to drill the hole for the bolt a little bigger... was all
    72 Chevy Blazer, 327, SM-465, NP 205, 4in lift, 35 in tires
    Was About to put in 400 SBC/ 700-R4
    Now trying to go 454/ 400/ 205 setup
  4. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    I have a couple of these...it does sorta look like a big conduit clamp. If anyone can use mine, send me a PM.
    I replaced my original seat with a 2000 Suburban 3rd row seat and wont be needing em.
    Matthew Meyer
    matthewm@inhollywood.com
    '71 Ochre K5 - 4" Lift 35"s
    ZZ4 350 - 700R
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I"m interested how much you want for one of them? how is the new seat working out?
  6. wrath
    Mar 4, 2001
    182
    Grayling,Michigan
    Thanks for the help so far guys...
  7. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    wrath, you can see the brackets in the photos of NuBomb's 72 Blazer bed clean up - <a target="_blank" href=http://coloradok5.com/gallery/albuo30>http://coloradok5.com/gallery/albuo30</a>
    They are the flat things welded to the bed. His look just like the brackets in my '69.
    '69 K-5/350/TH350/35's & 6" Lift
  8. wrath
    Mar 4, 2001
    182
    Grayling,Michigan
    OK, I have them flat pieces welded in my bed also..is there mounts attached to the seat also..maybe I need a pic of a seat (underside)with brackets attached if any are..
  9. wrath
    Mar 4, 2001
    182
    Grayling,Michigan
    Still looking for these brackets if anyone has a set or pics would help also..thanks
  10. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    I don't have the rear seat for mine now but if I remember right from my old one, there are two clips on the front of the seat and the back has holes trough the frame of the seat. The seat belts bolt into the back holes. Someone correct me if I'm wrong.
  11. jmeador74
    Oct 31, 2001
    108
    Eatontown, NJ
    Bracket picture
    Here are the electrical conduit clamps I used in my blazer. When the actual seat is bolted down in the back. The front part of the seat has a bar that runs along the floor board. well that bar should eventually end up close to a hole that already has been drilled and threaded. All you have to do is supply the bolt and then use these clamps.
    The only bad thing about this is that you don't get to pop any more wheelie's in the back seat once you bolt it down in the front. :D
    -James
  12. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Here ya go. First pic is pass front bracket. Others are rear brackets. Mine is a 70 also, so should be the same.
  13. wildbilzrydn
    wildbilzrydn 1/2 ton status
    Jun 27, 2005
    118
    Joliet, IL
    I saw a set on ebay and they are really frigging expensive. I thing conduit clamps are way to lightweight for a seat, I would make some out of some 1/8" flat stock if it were mine.
  14. jmeador74
    Oct 31, 2001
    108
    Eatontown, NJ
    Well my decision to go with them was because most accidents and incidents come from the front. So the back four bolts do the majority of the work. I just needed something to hold down the seat in the front so I wasn't popping anymore wheelies with my rear seat. And the way it feels it seems pretty sturdy... By no means isn't strong. But has a good stiff feel to it.
    -James
  15. wildbilzrydn
    Jun 27, 2005
    118
    Joliet, IL
    James,
    I don't mean to sound judgemental. Sorry if it sounded that way. If you get rear ended though.... Or spin... Admit it, it would take you about 10 minutes to make a safer set.
    Bill
  16. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Those conduit clamps are HORRIBLE!!! :eek:
    I don't care what excuses you make....your passengers deserve a lot better than that!
    :mad:
  17. jmeador74
    Oct 31, 2001
    108
    Eatontown, NJ
    Bill,
    No, I understood what you meant and I didn't think you were too judgemental... I just posed another fix on this thread to give other people ideas. Or what they can do.
    Greg...
    You know I used to sit here and read some of the stupidest things on some of these pages that people would do to their trucks... well what you had said about my posting of those clamps had made me rethink (STUPID!!) of going to something stronger. I just don't work with fabricating metal so I went for the quick fix on this one. If I come up with something other than going factory. I will be sure to post them up. But, for right now... I have the prject of swapping engines and when that is complete and running good... I think this might be my next fix.
    -James
    Sometime it only takes a good friend to go, "what in tarnation!" To make you think of your decisions about having sone something. Thanks Greg.
  18. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    i can take a picture tomorrow.
    mine is complete in a 1970 2wd blazer, i have extra rear brackets. but i do need front brackets. if anyone has some?
  19. 72jimmycst
    72jimmycst Registered Member
    Sep 5, 2005
    17
    Rapid City SD
    I think this will work or do you need pics of truckbed?
  20. 13lazer
    Dec 30, 2004
    115
    San Pedro, CA
    those are the ones
    are you selling those bench seat holdowns, i need the extra set for my 72 k5 project. if they're around i could also use the seat mounts that are held by those little things. i have the rest including the rear brackets and seatbelts. thanks
    aaron
