Rear seat mounting brackets-72 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ressurection, Jun 21, 2000.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Can anyone direct me to where I can get the mounting brackets for the back seat of my Blazer? The truck came without a seat, but I have one now and want to mount it w/oem type brackets. Thanks!
    You can't beat going Topless!
  2. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    They are hard to come by. No one sells them aftermarket. The back of the seat bolts directly to the floor, but the front requires brackets that clip over the tube of the seat frame. I made a set for mine. You see a seat with hardware come up for sale on the net every once in a while.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    For the tube in the front of the seat I used Ubolts from a local HW store. Just got the right size to just fit over the tube and drilled a couple holes and wala instant bolt in. The rear of my seat has two L shaped brackets and the bottom of the L has a hole in witch a carrage bolt goes thru and bolts it down.
    Good luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>my K5 has a rear seat from a 80s blazer. i used box tubing for the front mounts and (please don't laugh to hard) F*rd br*nco spare tire latches (the part that goes on the tailgate to hold the carrier closed), i cut them so they would work, that was almost 2 years ago, and I haven't had a problem yet. hope that helps</font color=blue>
  6. Ressurection
    May 9, 2000
    360
    Thanks for the advice guys! I checked out one at a boneyard today, and it had no rear seat mounts either. But the persuit will continue!
    Pete.
