Rear seat seatbelts
Discussion in 'The Garage' started by mogas, Apr 8, 2004.
  1. mogas
    mogas 1/2 ton status
    Apr 5, 2004
    118
    Flagstaff, AZ
    What year did they start using three point belts for the rear seats in the burb's and are they relatively easy to retrofit?
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I have only seen one with the three point belts in it. If I recall correctly it was a 90 or a 91 and had a roll bar in it, which is where the upper portion attached to. It was a prior park ranger truck that they guy got a deal on. Most without the cages have lap belts. Hope this helps.
  3. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I have a 91 jimmy with shoulder harnesses attached to the top
    We are going to relocate the shoulder belts to a roll cage for safety in a severe roll over situation /forums/images/graemlins/yikes.gif
    does anyone know if the fact. system can be re-used or will I have to find a different one??
  4. mogas
    Apr 5, 2004
    118
    Flagstaff, AZ
    Actualy, I was mostly curious about Suburban rear seat 3 points but you gave me an idea. I think I'll cage the 'burb
    and use the cage for the mount points. What dya think?
