REAR SHACKLE BUSHING SIZE????
Discussion in 'The Garage' started by fwc, Oct 10, 2004.
  1. fwc
    fwc Registered Member Premium Member
    Nov 2, 2003
    84
    Northern Virginia
    91 Jimmy with stock springs...Getting ready to order poly bushings for my rear spring shackles (shackle to frame) and they are asking what the frame hole inner diameter is:
    1-3/8, 1-1/2, or 1-3/4? Do I need to measure or should I have 1-3/8?
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    most are 1.5 or 1-3/8, or at least the couple of sets I have done. There is a steel collar inside a lot of them that when removed will fit the 1.5" style.
    [edit] thinking of OD on shackle tubing [edit]
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    mine was 1 3/8"
