rear shackle flip
Discussion in 'OffRoad Design' started by 3car, Dec 24, 2001.
  1. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    does the flip kit effect the ride in any way,i have 4 "blocks..if i installed the kit and got rid of the blocks,the ride height would be the same?
    eatin'fords and shittin'dodges down in the sunshine state.
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Yup , and it doesn't have the effects of axle wrap and its safer [​IMG]
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    BUILT NOT BOUGHT
    <font color=red>MERRY CHRISTMAS</font color=red>
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ride height should be roughly the same. It should actually be a little softer due to geometry changes with the shackle in compression rather than tension. However, for the same reason, your ability to haul heavy loads or tow (especially tongue heavy) is seriously degraded.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  4. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    baddog is right...your towing abilty goes right out the window...i towed my 72 blazer from pheonix az to stockton ca...that was a intesting experance...i never want to do it again...its very squarly with that much weight...but towing small utility trailers or something like that is no big deal at all.
    Chaz
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Ride height should come out very similar, within 1/4" or less. Towing ability comes down to a lot of factors so I wouldn't be terribly worried about that one. Ride quality should be similar to what you have now, it may seem softer if you went up from stock ride height, but since you already have the block you're used to that by now.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  6. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    thanks for the info.i really want to get rid of the blocks,but i do pull a trailer that weighs about 4000lbs w/500 lbs tounge weight on a regular basis.will this work out ok?
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I think we took care of this Q on the phone or other email, jist of the story is that with the kind of load you have other concerns that are going to be more important than the flip. But the flip does work fine for towing if the rest of the truck is set up right.
    SW-ORD
