Rear shackle help
Discussion in 'The Garage' started by 88K5Jimmy, Aug 17, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Right now I have an Echobit flip and stock leaf springs and shackles. The rear sags just a bit and I would like to put some extended shackles on. However, what length would give me a little extra lift without compromising excess body roll?
  2. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    you would probably have to go with a 4" rear shackle to accomplish enough lift to even it out. and that would only give you about 2" of lift. i would think that it would be better to install a 2" add-a-leaf instead. that would not comprmise the pinion angle where as the longer shackles would.
  3. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    How much sag are we talking about here? I wouldn't go with a longer shackle. Maybe get some old leafs out of the junkyard and put together some packs with longer leaves. You could use a 1" zero rate in the rear also. How about taking short leaves out of the front spring packs?
  4. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Ohh, forgot to mention, I have the ORD add-a-leaves in the rear already. Also, there is one small leaf on each front spring pack that I have thought about taking out.
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    what? longer rear shackles will help the pinion angle if the shackles are flipped.
