rear shaft slip travel?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Chris, Nov 21, 2005.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    how much travel does your aftermarket rear shaft have? is about 3-4" enough? im doing the diy4x flip w/ 6" shackles and 56's, and move the axle back an inch or so. just doesnt seem like thats enough.
  2. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    anyone? :confused:
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    Standard shafts don't usually have more than 2.5-3" of slip in them. Is that enough? Well figuring that out is part of building a custom suspension.
    Simple trigonometry is all that's needed to figure out how long your shaft should be at stuff, droop, etc. The amount of slip needed is proportional to the amount of suspension travel available. The problem is that adding lift doesn't mean that a longer driveshaft with the same amout of slip will work. Unless you space down the bump stops or limit the stuff somehow, the minimum driveshaft length is the same as stock.
    You pretty much have to design it for full compression, so that you don't bottom out the driveshaft into the T-case on stuff. Then you put in as much slip length as you can afford. It's OK to overextend a little and booger up the seal, as long as you still have enough spline engagement that it doesn't come apart or bend the splines.
    As for moving the axle backwards, that should translate directly to a longer length needed.
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Now theres an oxymoron.... :rolleyes:
    -Harrison
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    In most cases a 5 1/2 " slip is what they come with (thet's full one end to the other slip -until it pulls appart) and if you run it between 2-2 1/2 " off bottom it sould not pull apart -its a centered axle- they don't pull away like a off-set front does- Jess
