Rear shock bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by The Loner, Aug 18, 2002.
  1. The Loner
    The Loner Registered Member
    Aug 1, 2002
    13
    Davis, Ca
    The spec in haynes for the upper rear shock bolts is 140. I went to check them and they looked tiny. They were 11/16 and not the original bolts. Do I have the wrong size bolts in there or is the haynes wrong? 140 seems like a lot for a bolt of that size. Wanted to check before I broke the bolt and busted my knuckles. thanks--B
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    snug and a 1/4 turn is all you need with a big washer and a lock washer.
    no need to whit knuckle it. if ya ever have to remove it on the road or trail you might not have a breaker bar handy
    grant
