Rear shock location
Discussion in 'The Garage' started by alf4444, Sep 28, 2005.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Well now that the 56" springs are installed as well as the shackle flip :bow: its time to look at the shocks. During the install is when I noticed the rear is extremly limeted in droop by the shocks :( . Also somewhere along the way other adjustments were made. The pass. side has a hole drilled in the frame that has since been rounded :rolleyes: out and the drivers side has a plate on top of the frame. So what are my options Can I drill a hole lower in the frame and mount there or should I save up and get some trick 16" travel remote resivour shocks
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    These spots in the frame you mentioned, are you saying they would make inboarding the shocks a problem? Most people make a brace that goes across between the frame rails to mount the upper ends of the shocks.
    Your going to want to get some new shocks to go with your new range of travel back there. You can get some pro comps from summit for about 34.00 each. They're not remotes, but they have around 13"-15" of travel.
  3. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    thats pretty cool
  5. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Forget all the kick arse stuff in those pics. I want the shop? Are the body lift spacers on the roll cage for a hilift mount?
  6. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    Yea they are...
  7. TLCOR
    TLCOR 1/2 ton status
    Aug 16, 2005
    333
    At ya mama's!
    I want your shocks. [​IMG] Seriously, that looks very awesome ! Nice rockers, doors and overall setup..
  8. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    whos setup is that blue is he local?
  9. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
  10. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    Yup, It's Sid...
