Rear Shock Mount Replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by onlychevy6, May 14, 2003.
  1. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    I have a 78 Blazer 4 wheel drive. my rear shock mount on the drivers side has broken. how do you repleace it and where can i get a replacement from. checked all local junkyards with no luck..
    thank you
    /forums/images/graemlins/k5.gif
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    if it's the mount no the axle, 4WPW has them, don't know about the frame mounts though.
  3. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    thank you for that information. unfortunataley it is the frame mount support for this one.
  4. Greenie
    Greenie Registered Member
    May 11, 2003
    28
    Glendale Arizona
    This happend on my 89. The top mount on the frame cracked so many times it could not be fixed anymore. My local Chevy dealer had the mount. It is rivited in. You will to drill the rivits out and use bolt to replace it. Use the self locking nuts. You will not want to have to re-tighten it again. This is not a fun job. Good luck.
