rear shock mount
Discussion in 'The Garage' started by skelly1, Apr 18, 2004.
  1. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I noticed when pulling the 10 bolt rear out, that the left rear frame shock mount is broken. Anybody have a cool fix for that?
  2. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I wonder if that's a trouble spot. Mine's not busted, but it's bent pretty badly. I think the Rancho shocks I had in there were too short (I used what they said for 4" lift) and it was getting yanked on all the time when the truck leaned. For some reason the shock mounting bolt up there always seems to come loose on me too, which doesn't help because it's making the hole oblong out.
    I'm no help here, but I'll be monitoring this to see if anyone else has done anything smart about it. /forums/images/graemlins/grin.gif
  3. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Forgot to mention, the right side bolt is loose.
  4. dyeager535
    26,979
    Don't have a real fix for the problem you now have, but to prevent it I had my dad weld the shock mount bolt in place (as opposed to just using the nut on the back) so that it could never loosen up.
    If/when you do this, make sure not to keep using those nuts that screw up the threads, since you can't remove the bolt that easily. /forums/images/graemlins/smile.gif
    My suspicion with these setups and their problem is that once the bolt works loose just a hair, every bump is a hammer blow to that mount, and eventually it fails.
    GM figured out that was a problem, as they started using bolts that were pressed in like wheel studs.
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    weld it /forums/images/graemlins/dunno.gif
  6. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    couldnt you throw some ford towers up in there?
  7. greybeard
    greybeard Registered Member
    Sep 29, 2000
    43
    Dallas, Texas
  8. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    MIne broke, welded it, broke welded it, broke welding it, finally replaced it. The rivits that hold it in are tough to get out.
  9. tarheel
    tarheel Registered Member
    Apr 11, 2003
    65
    GA
    I had the same problem. I got the hoop setup from Missourri Offroad Outfitters. I could not be happier!! Check it out...
    clicky thingy-mabob /forums/images/graemlins/thumb.gif
  10. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Do you have a picture of what it looks like installed? How difficult was it to put on? It kinda seems like the tank would interfere horribly when trying to put the crossmember on, but I can't exactly visualize how it goes either.
