Rear Shock Mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JOEBLAZER12, May 8, 2000.
  1. JOEBLAZER12
    JOEBLAZER12 Registered Member
    20
    I just noticed that there is a little bit of play in the rear, upper shock mount on the drivers side. I tried to tighten it but the shimmy is still there. I think maybe the hole in the upper bracket has been worn down, making the hole slightly larger. Is there something I can do about this(use larger bolt maybe, etc). I've heard that if this mount goes bad, its a real b***h to repair. HELP!!!
    JOE
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Mine had to be welded back in. It was a cheap fix.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
  3. JOEBLAZER12
    20
    Blazer 79,what do you mean by welded back in? Did your entire braket come loose, or was the hole in it enlarged?
    JOE
  4. JOEBLAZER12
    20
    Blazer 79, what do you mean by welded back in? Did your entire bracket come loose or was the hole enlarged?
    JOE
  5. Blazer79
    1,816
    I was a kid when that happened. The part was still in there but it was loose and there was no way of tightening it, so what my father did was to weld it back in. I'm not sure if it was the same one or a different one.
    Hope this helps.
  6. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    If the bracket is still tight.Unbolt the stud and weld a plate over the hole then redrill the proper hole.I think the stock mount is at most 1/8th thick.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    I had a rear mount break and I had my friend weld a new one in and I also bolted it where the factory rivets go.
    Mike
    82 GMC Jimmy "Emmett"
    IN TOO DEEP Off-Road Club
