Rear shock mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rts, Jan 19, 2002.
  1. rts
    rts Registered Member
    Jul 28, 2001
    15
    Dallas, TX
    '89 K5
    The left rear upper shock mount is broken. How hard id it to replace? Does it bolt on, or weld on? Do i have to lift the body off the frame to get to it?
    The Chevy house wants $18 for the bracket. Is it avaliable cheeper?
    Thanks.
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    That bracket is riveted on from the factory. I repaired my upper left bracket once, lower right side twice and upper right side once then I got fed up and relocated the upper shock mounts to fix the problem for good. The rear suspension on a K5 has a lot of flex and the shocks mounted in the factory locations tend to bottom out easily and shear mounts off.
    Here is a look at relocated shocks on Steve Fox's Blazer.
    <a target="_blank" href=http://coloradok5.com/ranchoreview.shtml> Shock relocation</a>
    You'll see the fronts and rears relocated...in my opinion the rear is much more critical because it will prevent further breakage as well as allow for more flex.
    As for repairing what you have...when I did the left side bracket I welded up the broken bracket. It is difficult to get to and I would guess even harder to replce than to re-weld.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I have one I can take off my frame, I'm not using it..I'm doing a relocation set up too.
    let me know.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    im a k15 guy, but on the k5's dont you need to get rid of the fuel tank?
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  5. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    If you want to eliminate those problems all together, then contact <a target="_blank" href=http://www.mooffroadoutfitters.rockcrawler.com>Steve Frisbie</a> and order the new upper shock mount crossmember and housing brackets for your application. I have this setup and it is going to be awesome. I will let you know how things go after the installatoin.
    Later,
    Neil
    Mudzer 1978/91 K5
    <font color=blue><a target="_blank" href=http://www.mudzer.rockcrawler.com>www.mudzer.rockcrawler.com</a></font color=blue>
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I broke my upper rear right shock mount off as well. I ordered the replacement part from GM for $14 but then I decided to do with Steve Frisbie's shock relocation kit...so that is now on order....I still have the factory bracket if you want...I'll sell if for $5, you pay actual shipping...
    Chris
    Was that a speed bump? No, just a Rice Rocket </font color=red> <a target="_blank" href=http://coloradok5.com/gallery/fortcollinsram>My 87 Blazer</a>
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Which side? passenger or driver? I need the drivers side.
    My Chevy isn't broken, its just out of gas.
