Rear shock mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Sep 17, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My back shock mount broke today. I dont know if its the original one because I looked at my friends 86 C20 and the rear shock mount is different. His goes thru the frame and mine is a plate on top of it with a 90 deg. angle that the shock bolts to. This is only on the left side. the right has it going thru the frame. This one is riveted to the frame with 2 rivets but I think they are still in place and it tore around them. Would welding it back togeter be a bad idea? I know it would weaken it but would it be enough to matter? Also does anyone know where I can get a new mount? LMC doesn't have them and I called the dealer but they couldn't find it. Thanks in advance
    90K5
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    My 82 has the same set up as yours with the passenger side going through the frame and the driver side mounted to a plate on top of the frame......I just put new shocks on last week and was wondering about that too. Any input from the k5 brothers ??
    <font color=purple>L8r,
    .Riz.<font color=purple>
  3. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
    They're notorious for breaking. You can weld it back together and see how it holds up... Fabricate a new one (they're really simple)... Or buy a replacement (I've seen them advertised a few places before). Mine broke and I just welded a 3/8 inch steel plate to the frame vertically and drilled a mounting hole for the shock in it. Works great.
    <font color=red>~BigBurban</font color=red>
    http://www.geocities.com/crash607
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I've broken my drivers shock mount twice. The first time I welded the sh!t out of it, the second time the mount on the diff sheared. I guess I'll have to re-locate the way I have my shocks to keep them from bottoming out.
    Rene
  5. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Yeah, anyone have any good ideas on shock relocation for the rear. My mount in the rear is cracked from bottoming out. If not i am going to start investigating my own possiblities. Thanks - Doug
    Doug Krebs
  6. Cerote
    Cerote Registered Member
    Aug 25, 2000
    12
    Las Vegas, NV
    My driver's side mount is thrashed also. I found an old aircraft towbar at work that has a really heavy piece of steel on the end of it that is shaped like our mounts. I'm sure gonna try to rig it up this week 'cuz I'm tired of bouncing around. If it works, and I can find some more of those towbars, I'll let y'all know.
    Keep yer fingers crossed! :<)
    I H8 POSER TRUCKS!!!
    '86 K-5, 305cid, SM465, 31" BFG A/T...
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i took the shock off and I'm geting someone to weld it up for me cause I don't have a welder. I'm surprised that it doesn't ride as bad as I thought it would without the shock.
    90K5
  8. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    Broke my left rear twice, no bump stop extentions after installing lift caused the problem, G.M. sold me a new mount for 20 bucks cdn .As for using a torch around the gas tank, well you can probably guess what could happen! This job is a pain in the butt.First I lowered my gas tank, be prepared to break the threaded bolt that's incorporated into the tank straps because the nuts are usually seized on. You'll have to buy new straps or weld the old ones back together, unless your real lucky and they actually do come off. With the tank lowered, and resting on something so you don't have to unhook all the lines, you should have access to the inner frame under the mount.I used an air chisel to cut the old rivet heads off,(loud!) it was a bit of work, but I didn't blow up. After removing the old mount, it' just a matter of bolting the new one in place using the old rivet holes. This job isn't really that tough, it's just the tight spot you have to work in that makes it bad.
    MIDCAN k5 " DIG A HOLE!!!"
