Rear shock mounting options
Discussion in 'The Garage' started by kennyw, Sep 5, 2005.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Drivers side frame shock bracket is broken on my '85 GMC Jimmy. Pass side where it goes thru the frame rail isn't looking too healthy either. Anyone have pics of some other mounting options? Might as well upgrade to the inboard style now rather than try to patch up the stock ones.
  2. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    mine broke about 2 years ago coming home from school. i just drilled into the frame just below where it used to sit. its compressed a couple inches more than before but i dont really care, and i cant feel a difference.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    i know of a few ways,LOL
    I just don't have any pre made.
    If you have the metal I can tell ya how.
  4. kennyw
    Jun 9, 2002
    13,224
    94
    Got any pics of your shock mounts? I can get the metal and build it myself... just need to see some concepts mainly.
  5. TLCOR
    TLCOR 1/2 ton status
    Aug 16, 2005
    333
    At ya mama's!
    I would make new mounts all around and mount them in an "A"..
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I don't have pictures as I haven't done it yet, but I'm planning on taking a piece of 2.5" .25" wall square tube, cutting it into two or three pieces, and putting flanges on every end. The outsides will bolt to the frame and the insides will bolt to each other. I'm gonna drill holes at different positions for different shock angles and just run a big grade 8 bolt through the tube and put one shock on each side for duals. Not fancy, but it'll get the job done. For the bottoms I'm probably going to take an oversized spring perch and just weld shock tabs to it. Once again, not fancy but effective.
  7. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Heres the way I did mine
    2" thick wall tubing from framerail to framerail with a short piece of 3" "c" channel used to box the frame section. I then drilled a hole in the tubing inserting the original shock studs from the frame to mount the top. For the lower area I took an old set of perches (no good) cut them to size drilled the center hole out and welded in another set of shock studs. Easy and cheap. Works great.
  8. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Last pic
    last picture
  9. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    the bracket that mounts to the frame to hold the shock isnt that expensive. i got mine for less than $10 from the dealership.
    no fab work required, just getting rid of some rivets.
    ryan
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    MO Offroad's kit
    really nice stuff!!!
