rear shock mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stan1688, Nov 14, 2006.
  1. stan1688
    stan1688 1/2 ton status
    Sep 13, 2006
    779
    Independence, KS
    I just bought a 91 k5. One of the rear shock mounts has broken off. Any body got any ideas, or something that someone else has done, on how to set up some new mounts? Pics would be good. Thanks. -Shane
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Is it broken at the axle or the frame? If the frame, which side?
    Jimbo
  3. stan1688
    Sep 13, 2006
    779
    Independence, KS
    Its broken on the drivers side at the frame (top mount).
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
  5. stan1688
    Sep 13, 2006
    779
    Independence, KS
    Thanks for the help.
  6. 83k5blzrbob
    83k5blzrbob Registered Member
    Aug 7, 2006
    40
    3
    Waterford Michigan
    I had the same happen on my 83K5, I removed the shocks, ground out the holes (they were elongated from damage) and welded in new steel plates with the appropriate size drilled holes. It looks stock and should be plenty strong enough.
