Rear Shock relocation.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Jun 18, 2002.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    It's relocation time. I have broken the rear driver's side shock mount again and it is time to relocate the shocks, I am tired of fixing it. I have been looking at different members setups and want to know if there is any difference on which side of the axle you mount the shocks?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    You mean how one is on the front side and one on the rear side of the axle? I think I remember reading its done for axle rap or something like that.
  3. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    No, I mean when you relocate shocks and put them both on the same side of the axle, does it make any difference which side they are on. For example, Steve Fox's are mounted to the rear of the axle, which to me seem to offer a little more protection; however, I have seen other members with them mounted to the front side of the axle.
  4. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I used MOO relocation brackets and they are mounted on top of the axle. They work great!!
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I mounted my shocks on the front of the axle.I have super mega axle wrap because of way soft springs and being fairly light.I dont think mounting in the front or rear of the housing has a whole lot of play in the axle wrap picture.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    55willys makes a great setup. cost half as much as MOO
    i got it. GREAT WORK JEREMY!!
    i am buying more from him to.
    grant /forums/images/icons/shocked.gif
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Thanks Grant.
    Yes i do make a rear shock set up.
    Also it does not matter what side of the axel you mount them too, if you are a rock crawler I would mount them to the back side as to get them out of harms way.
    -Jeremy
    Howlin' Off Road
    "Answer the Call of the Wild"
  8. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Mine are mounted near the top towards the front of the axle. My upper mount is also forward of the axle so the shocks lean inboard as well as forwards a little.
    Rene
  9. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Derf, I mounted mine on the inside. I have my rear axle moved back ~ 3", so there is no way I could've mounted it on the other side (like Fox). But like the other said, it won't really matter which side you mount it. Personal preference I guess. Never had an issue with it.
    Friz, I'm running super soft 58" custom rear leaf springs (150lb spring rate). I welded on some custom perches that are really long (about ~ 7" long) to help "prevent" axle wrap. Drilled the hole up about 1" (to move axle back another inch (making it 3" total)) and I think that also helped in preventing any axle wrap. So far, I haven't noticed any. Just a suggestion for you.
    Boss
  10. goblazeinco
    goblazeinco Registered Member
    Nov 9, 2001
    33
    Longmont,CO
    Jeremy, How much are your rear shock setups? I have been considering doing something like that. Also do you have a pic of the upper bracket...I looked through your pics but didn't see one.
    Clay
  11. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    yeppers, gotta recommend 55willys (Jeremy's) shock relocation kit. Very nice, and as noted, dirt cheap compared to the competition! /forums/images/icons/laugh.gif
    J
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
  13. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Ditto! Check out this kit.
    Heres the Catalog Page
    Shocks are mounted on the top of the axle, which keeps them out of harms way. You can adjust angles and such with this setup, plus you do not need a super long shock.
  14. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Hey Jeremy how much for the kit?
  15. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    A lot of people put them both on the back side. I'd have to agree with them that this makes more sense because of impact. If I were doing it on a trail rig I'd put them on the backside and angle them in though (but not straight up, behind the axle still). This will allow you to have more travel.
    FYI:
    The shocks on opposite sides of the axle is to help get rid of wheel hop and in theory it should help axle wrap during shifts (but not during acceleration). If you don't like to do burnouts or take off like a top fuel dragster then it doesn't matter.
  16. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Mine are mounted on the front of the rear axle /forums/images/icons/tongue.gif due to the electric fuel pump hindering putting it on the rear. No axle wrap for me. Probably better for rockcrawling to put them on top of the axle tube or the rear but where mine is mounted (compliments of Jeremy aka 55Willy) you'd have to be in some nice rock craters to hit the 9012's........not that the hard core rock guys couldn't do it, THEY COULD!
  17. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    I think it looks real good ....I want one.....I like 55willy's better and the fact that it's built by a member weighs heavy on this!!! We should support our members not knock them, piss off with the other set up and catalog what a bunch of bullshit! Blazzin sounds pleased with his and that's what matters. Excellent job!!!!
  18. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I think both set-ups have their merits. Both are made by members here though. The MOOffroad set-up is made by Steve Frisbe who's been here sharing his knowledge and stuff for quite a long time.
    Rene
  19. twenty_below0
    May 16, 2001
    436
    In that case I retract my last statement!! Thx for the info Trusty, Yes they do each have there advantages
    Sorry Steve, no pun intended!!!
