Rear shocks through the bed? Comments on Pics (Chops)
Discussion in 'The Garage' started by zakk, Oct 11, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Ok, here is a few of the ideas i have. I am thinking a bent 1.5" HREW .120" shock hoop(red ink). Then triagulate the two hopps against each other (purple ink). The "rough idea" of where i would cut the floor is in black ink. No rear seat is wanted, storage space only needs 3 ammo boxes, spare, cooler.
    Picture #1 cuz the damn Pics won't link
    I would weld the hoops to the frame, and try to tie it to a cage when i get one some year
    Pic #2 cuz the damn things STILL will not link!!
    Please comment, flame, rant, question, etc. /forums/images/graemlins/thumb.gif
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i cant see nothin
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Well there was a nice picture of a pre-runenr blazer in the classifieds on race-dezert.com with a setup like you want, but they lost all the classifieds and now I cant find the picture.
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i'm gonna do something like that too. i've got some bilstein 6100 that are 35" fully extended. but what i'm thinking about is making the upper mount connected to the cage this way i would one less penatration through the floor.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Unless your cage is solid to the frame, you're going to lose some damping by making your shock mounts attach to the cage. /forums/images/graemlins/ooo.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/wink.gif
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the hoops are welded to the frame /forums/images/graemlins/rolleyes.gif they are attached to the frame to help prevent them from folding
  7. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    How will the shocks come up from the bottom? Looks like you are plannin to mount them at the apex of the peak, if so wont they hit the frame when the suspension articutlates? /forums/images/graemlins/blush.gif The idea looks good, but I think you will have to move the shocks mount out onto the purple brace for clearance. You can also make that brace your spare tire holder then also.
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    i think it'd be difficult to bolt the rear seat back in /forums/images/graemlins/eek.gif
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The rear seat is the only reason I havent tubbed the back of mine and raised the shock mounts... /forums/images/graemlins/frown.gif
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    right, they angle in a bit, not sure how to put that in the lines, i am a techno-tard:) also i do not run a rear seat, so that is not a consideration.
    My idea is to have in angled in so that the force "pushes" on brace between the two towers, and when welded to the frame, it triangulates against "itself" for lack of a better term.
    thanks for the input! keep it coming!
  11. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    link no workie /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif
  13. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Zakk,
    I think he was talking about this one:
  14. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Zakk,
    I like the basic design off the hoop. Were you planning on mounting the shocks on the outside of the frame or angle / \ in towards the center?
    Most everybody running my rear suspension has clearance issues with the inner rear fenderwells at the top of the tire when full stuff /forums/images/graemlins/frown.gif... One guy (DJ) cut out his inner part of the wells, and was planning to build a shock mounting structure just like your design. I don't think he ever finished it, but you can see his "cut job" here.
    Now, if you were to start with his cut AND cut the floor back to the frame width, then make the hoops, and run the shocks on the outside of the frame up to the hoop, sort of leaning forward (kinda pointing toward the back of the driver's head)...
    I think that would be the best all around setup.
    Marv
  15. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Yeah... /forums/images/graemlins/thumb.gif.. thanks Greg. /forums/images/graemlins/grin.gif
    That shock location is very close to what I was trying to describe. Main diff would be that the whole inner well would be taken out too.
    Another advantage to this is you could make the lower shock mount attach to the top of the U-bolt plate or axle .... getting it up out of harms way. /forums/images/graemlins/thumb.gif
    Marv
  16. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    hrrrmmmm....I was going to place the shocks just inside the frame rails, so that it was out of harms way, easily welded to the frame rail, and pimpy
    What would be the benifit of angling forward? /forums/images/graemlins/confused.gif /forums/images/graemlins/ears.gif
  17. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Inside the framerails might work just as good.... but the closer together the shocks are, the less control they have over body roll. Remember SMP's truck (flexy 1st gen)? He had his shocks thru the bed sticking straight up inside the framerails. Put the lower mount pretty close to the pumpkin on each side. Worked great for droop, but even empty - the street manners of his setup are near the edge.
    Angling forward might give you a little more effective travel out of the shock - but still keep the mounts wide enough to give better street manners.
    Just suggestions.... /forums/images/graemlins/grin.gif If you do go "inside" the framerails, try to keep the the mounts as wide as possible.
    Marv
  18. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    This is exactly what I did with mine. They are mounted to the spring plates and run up and forward to the outside of the frame...
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Russ, do you have pics of that? i would like to see how shocks on the top of the packs would work.
    TIA!
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Here ya go...
