rear side panel boxes.need pics
Discussion in 'Audio' started by bckinblk, Aug 25, 2002.
  1. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    Well I am looking into making or buying side panel boxes for 2 10s or 2 12s .Any of you guys done this?? Plese post pics so I can get a better idea as to which ones I want to get.....thanks..........
  2. Rebel-Rider
    Rebel-Rider 1/2 ton status
    Sep 30, 2001
    134
    North Dakota
    i have thought of doing this myself i just dont know that you have that much room for a subwoofer in those panels unless u use the blaupunkt saucer subs i would be willing to make you side panels if you want out of wood or fiberglass let me know what you decide rebel102285@hotmail.com
  3. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    i got two 12's in mine 1 on each side and two front facing 6" mids click on webshots for the pics
  4. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    Wow those look great..That k5 must POUND ..Those are the type of boxes I want to get for mine .Do you have a spec sheet on them if so please send me a copy so I can start building them.Thanks
  5. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
  6. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Beautiful truck tightwork!
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd like to have some side panel sub box's, but the subs I plan on runnning require a min of 4.5 cubic feet per sub. Preform the best with 5.5 cubic feet per sub. I plan on running a pair of them. (15" MMATS Juggernauts) I also want to fire them upwards. With the side panel boxs, I asume the subs face each other. Is there any problems with cancelation ???
  8. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    as far as a spec sheet I did not draw any up. just get some messurements around your wheel wells. the pics show the shape of the box's. the sound is great outa the back the polk subs are real clean sound, i am pushin them with a 1,000 watt sony explode mono amp. runnin it straight at 4 ohms . i might drop them to 2ohms but the sound is nice right now. as for 15's in side boxes you may be able to flare the sides out to face them up in a 45 degree angle and the inside of the box would have to be made to go around the wheel well. I think 2 12" subs are plenty. maybe 1 15 behind the bench seat! thanks for the complements!!!! /forums/images/icons/wink.gif
  9. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    would you ever consider biulding some boxes like that for the right price?
  10. Rebel-Rider
    Sep 30, 2001
    134
    North Dakota
    Did you mean you wanted me to build you some if so yes i would be willing but shipping might be a little expensive email me at snatwick@dia.net thanks ADAM /forums/images/graemlins/smirk.gif
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    no i was talking about the other guy i liked his boxes..
  12. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    they are easy to make, it would not be cost effective to ship them, cause of wieght. go to your local home depot or lowes or what ever you got up there, get you 1 1/2 sheets of 3/4 osb 4x8 and 2 tubes of liquid nails (construction adheasive) 1 box of 1 1/2 drywall screws. and go over to the carpet section they have this outdoor stuff in grey and black, real thin works good on boxes. measure the distance between the wheel well and the tailgate that is the base. then measure the distance up your wheel well. I used a 45 deg. angle. then across the top of your wheel well to the back of your seat. then up about 8 inches the top of mine goes to the bottom of the topper. then back to the tail gate and down. made it about 7" thick look in my pics you can see cut boards for a referal. put it all together and use plenty of liquid nails to get a good seal. and pre drill screw holes. finish off with carpet use a staple gun for ease or spay glue but that gets messy. /forums/images/graemlins/grin.gif
  13. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    see my sig for a pic of mine. I still have them just collecting dust but like was said... it isn't too hard to make and wouldn't be worth it cause shipping would be killer
  14. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    how is that shaft working out for you? that for a 700r4? and how much scratch it cost you?
  15. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    pm'ed ya Tight
  16. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    10-roger
    guess I will try jess out everyone here seems to like him!
    hope its not cause he gives stuff away here. would hate to spend 300-600 on somthing that breaks.
    but I need somthing quick from the looks of your pic that slip yoke isnt in there that far.(look at my new engine album in webshots)
  17. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Yeah you don't have much in there and that angle in insane if that is actually hooked up. I like jess... he won't give you a bad product. For a very long time he wouldn't make a slip yoke shaft because the slip yoke is such a weak link. Have you thought about converting? Andy on the list can machine your case and using some dodge 208 parts you can make a fixed yoke case. I would look into it. Only way to go IMO if you crawl. Nice rig by the way... makes me miss mine /forums/images/graemlins/frown.gif
  18. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    That is impressive. Where did, or how did you get side panels with that soft diamond pattern in them?
