Rear side panels?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Roostr84, Feb 6, 2002.
  1. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    I am finally having some time to start working on the 69 again, among things to do are swap motors and tranny's as well some other miscellaneous things. my first concern is crafting some new side panels for the rear. What ever I make them out of I am coating it with some spray in bedliner, since I am going more for functionality than being perty. Anyway at first I had considered MDF since it was gonna house speakers but i was afraid even though they were coated they may get wet and discintigrate. Does anybody have any reasonably priced options? BTW its nice to be back
    Chris =)
    I think the exhaust fumes have finally gotten to me!!
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    If you make them out of MDF and coat the entire panel with bed liner to seal it you should be ok.
    '69 K-5/350/TH350/35's & 6" Lift
  3. Roostr84
    Aug 19, 2000
    451
    NJ
    I am just debating on whether the mdf or maybe a 1/2 in plywood would be better?
    Chris =)
  4. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    I made mine out of 3/8" particle board. I have a little more modifying to be done (getting the thing to fit perfectly) and then i'm going to have it upholstered the same material as my seats. I'll post pictures once that's done.
    Chris M
    <a target="_blank" href=http://www.geocities.com/chrism72beast/beastpage.html>http://www.geocities.com/chrism72beast/beastpage.html</a>
  5. Roostr84
    Aug 19, 2000
    451
    NJ
    Sounds nice. I am using my original panels as a template. I figure that I would coat the new panels so I wouldn't have to worry about damage from things in the back or water should i get stuck in the rain or perhaps get swallowed by a large mud puddle lol. As I mentioned before I am not too worried about prettyness as opposed to functionality since when i got this truck it had rust holes I could almost fit my head thorugh.
    Chris =)
  6. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    I think that I would go with the MDF over the Plywood or Particle Board if your concerned about moisture. I would think that the MDF is least likely to warp. You may even consider a polyurethane and then coat them with the the bed liner.
  7. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Believe it or not MDF is very water resistant. I believe they make house siding out of it as well. I"ve got a sheet sitting outside that's been there about a year and it is still usable. If you rough it up with some sandpaper and coat it with bedliner it should be good to go. If nothing else maybe get some fiberblass resin and coat it with that.
    Like em big and topless
    You call THAT...a 4x4....LMAO?
  8. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I agree with Les....mix up some resin and paint it on. I've done it on speaker enclosures and they are totally water-proof.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/goose>www.jmartin.net/goose</a>
  9. Michael
    1,576
    Sherman, Texas
    These are a bit pricey, but nice! www.jmartin.net/goose
  10. Roostr84
    Aug 19, 2000
    451
    NJ
    Yeah i think the MDF and glass/resin is a great idea. plus I have a ton of it around from refiberglassing the deck of my boat last year. This should be cake now. Thanks guys. BTW I saw the rod doors panels a year or two ago...they are sweet. Would look cool on a street machine or show truck... mine is just a whoompass trail truck. I think they are too high class for it lol..
    Chris =)
  11. Roostr84
    Aug 19, 2000
    451
    NJ
    BTW I thought MDF got all flaky when it gets subjected to water?
    Chris =)
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What about making them out of dimond plate? You could use dimond plate aluminum (lighter and looks cool) or steel (cheeper and stronger). I plan on plating alot of my truck w/ dimond plate steel and having a dimond plate gage cluster.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  13. Roostr84
    Aug 19, 2000
    451
    NJ
    Diamond plate was actually my initial idea but I though since I was mounting a speaker in there as well I was afraid of rattle etc. Still might consider it although the problem with that is the cost. When I checked a few places a full sheet was around 140.00 Would be badass though
    Chris =)
  14. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Diamond plate would most likely rattle unless you did the mdf and glued them together somehow.
    No, In the oldin days speaker boxes were made out of Particle Board, that stuff when it gets wet goes to poop. MDF is glued with a "space age" compound that helps it with water resistance and makes it stronger than particle board.
  15. Roostr84
    Aug 19, 2000
    451
    NJ
    Space age glue.... thats that new fangled stuff that doesn't do nothin for ya when ya sniff it right lol
    Chris =)
  16. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    beat's me, never been to a mdf plant, just had a lack of words so space age kinda fit. try it sometime when your talking to someone, kind find the word your looking for just insert the word banana, or just randomly say banana when your talking to someone, it's kinda funny
  17. yellowmoon
    yellowmoon Registered Member
    Dec 30, 2001
    94
    Modesto Ca.
    I got aluminum panels cut, but haven't got around to installing them. Hope I can bolt them in good enough not to rattle when I install speakers in them.
  18. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Roostr,
    You might be confusing it with "chipboard" or regular 'ol particleboard. MDF is a MUCH denser material.....you'll know it when you try to lift it. It's surprisingly heavy compared to normal plywood or particleboard of the same thickness.
    I still applied 3 coats of polyurethane sealer "inside and out" to my subwoofer enclosures just to be safe. I spent TOO much time building them to allow water to ruin them....
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  19. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Yellowmoon,
    If your not mounting subs in those panels they will probably be fine under the following conditions, you secure them well on top, bottom, and in the middle somewhere. You apply some kind of deadening material to the back side to take out the vibes.
    Greg I believe or someone anyway got some from grainer or McMaster Carr, or somewhere that was basically the same stuff as dynomat just larger quantity and much cheaper, you won't see it, it's not a fashion thing, (function before form here) so don't blow your money on the name brand sound deadener.
  20. rrent
    rrent 1/2 ton status
    Jun 10, 2001
    174
    Round Rock, Texas
    I don't know if you have access, but here in Austin (Texas) we have a couple of plastic stores - yep, they sell all kinds of plastic (some in different colors). I've used ABS on many occasions for fabrication it smooth on one side, but textured on the other - this textured side makes for a nice appearance - you don't see it used all the time, and its as easy to work as wood.
    Just a thought.......
    '72 Blazer mostly stock original "Baby Poop" yellow color
