Rear slip-yoke driveshaft questions
Discussion in 'The Garage' started by mplogic, Aug 7, 2002.
  1. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Hi all. I'm wondering how long the slip yoke is on a stock shaft vs an aftermarket one? Should be about the same, right? Also how far should the shaft extend out from the t-case to allow enough travel for the suspension at full droop and full compression?
    I picked-up my new rear cv shaft from AZ driveline yesterday but it is only 1/2" longer than my stock one??? I was expecting it to go in much deeper than it does. Just trying to figure out if this is normal or if I should have it re-done. It seems to have solved my vibration problems (without dropping the t-case) but for the money I spent, I want it to be right.
    Thanks for the help.
    Tim
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There isn't much you can do to extend the length of the slip yoke on that type of driveshaft, as one half of the slip yoke can't be changed. The male part of the shaft, that is inside the t-case, limits what can be done. /forums/images/icons/frown.gif If the female part of the shaft is made too long, then it can bottom out inside the t-case and break it. /forums/images/icons/shocked.gif
  3. mplogic
    May 7, 2002
    263
    Phoenix, AZ
    Right, gotcha. What I'm thinking is that the drive shaft tube they used is too short. Does anyone have a stock setup and can measure how much of the slip yoke is extended out from the t-case?
