rear slpine count on a NP205, how many??
Discussion in 'The Garage' started by arq, May 22, 2002.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    anyone know? I know the front may be a 10 or 32. how bout the rear output.
    ARQ.
  2. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    They are 32 splines.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    All NP205's have 32 spline outputs for the rear, including the 10-spline (front) manual-equipped ones???
    -- Mike
  4. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    32 spline. What I find annoying is that Furds 205s often have 32-spline front outputs while a lot of chev ones are 10. /forums/images/icons/frown.gif
    J
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    All: Rears are 32.
    All Ford: Fronts are 32 (IIRC)
    Chevy: 10 and 30 spline fronts.
    Dodge: Who the heck knows /forums/images/icons/wink.gif
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    The Chevy front output 10 splines were in the first design trucks, which run up to '76.
    '77 and newer t-cases have the 30 spline front output shafts.
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    another question. are front outputs 30 or 32s?? i have a tcase at home and i can put the same flat flange on front and back outputs.
    ARQ.
  8. Leadfoot
    Nov 28, 2000
    3,112
    You can swap in a Ford 32 spline front output shaft into a Chevy case (that is what I did, see my pics section.....it's in there somewhere). I'm assuming you have a front 32 if you can swap yokes front to back. Normally Chevy had 10 or 30 spline (there is a rumor that they may have had 32 from factory but I never have seen one).
  9. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    The difference is whether you have a manual transmission or an automatic. My '79 NP205/465 combo had the 10- spline input shaft while my new input shaft, to fit my TH400 had the 32-spline shaft. I ordered the input shaft and all parts from www.4xheaven.com in NY and they gave me everthing I needed as well as a great deal of infromation on the cases. Hope this helps, Gary
  10. Leadfoot
    Nov 28, 2000
    3,112
    You are right, but that is concerning the front INPUT shaft (which you are correct in the older 205's as the manual had the 10 spline input shaft, the 350 auto had 27, and the 400 had 32 spline female IIRC, but the newer 205 the manual trannys used a 32 spline input as well), I was describing the front OUTPUT shaft in my earlier posts. Just wanted to keep people from getting confused....as I often do /forums/images/icons/blush.gif.
