Rear spring front or back
Discussion in 'The Garage' started by bnate, Jun 11, 2006.
  1. bnate
    bnate 1/2 ton status
    Mar 6, 2004
    138
    San Jose, CA
    I know, dumb question.... :blush:
    Removed the rear springs to do zero rates and shackle flip.
    The SECOND to the top leaf spring has one side that wraps approx half way around the spring eye. The other side stops short of the spring eye, like a normal leaf.
    Which is the front or back?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    The top pic should be the front
  3. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    does that look like the top picture spring is Broken/cracked or am I seeing things. look at the second leaf.
  4. bnate
    Mar 6, 2004
    138
    San Jose, CA
    Took a look again at the leaf in question, no it is just the picture angle. There is some kind of indent or something right where the 3rd leaf from the top ends. There is also a leaf pack shim-thingy in between the leaves.
    So does the leaf that wraps around the eye give it a bit more flex...or does it do anything....what's the use of it???
    thanks for the replies.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    It helps prevent (or at least minimize) axlewrap.
