rear spring lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DALE, Mar 19, 2001.
  1. DALE
    DALE Registered Member
    Aug 27, 2000
    44
    hey everybody. i just got back from my local spring shop. my rear leafs are really sagging.the guy at the shop said he would build me the same as stock leafs with a 1 or 2in lift in the leafs to compensate and make the truck sit level. i have 4in blocks in the rear.what should i do??? a 1in or 2in lift in the springs to make it sit level???. the shop said the truck would ride better with close to stock springs and that there is nothing wrong with having blocks.they said if i get 4in lift springs it won't ride as good. please help i need rear leafs soon as i just snapped a leaf in the rear this past saturday.
  2. Lpasotx
    Lpasotx Registered Member
    Mar 6, 2001
    30
    just buy a 2inch add-a-leaf throw it on and there you go worked for me and i have a 4inch block in the rear my leafs werent sagging but it will go up 2 inches i have a six inch lift. if yours are sagging well there you go back to stock check my jimmy out jimjim.coloradok5.com
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    If you put stock rear springs back on the truck should not sag.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    .02c
    NO!! Just say NO to blocks!! Stock ride? What the hell is stock ride? Dude I would not bandade the issue! Get replacement spring packs or some prefer a shakel flip. I have Superlift 5" rear spring packs to go with my 4" Rancho fronts. Block cause axel wrap and if you have killer traction that wrap will make your rear go BOOM! Just say no to blocks! Stock ride?? That stament kills me!
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
