rear spring location?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crowley, Feb 6, 2004.
  1. crowley
    crowley Registered Member
    Oct 26, 2003
    24
    Phoenix, Az
    I'm planning on installing a set of 60" springs in the rear of my '87 with a shackle flip. I'm tossed between re-mounting the factory sprin hangers, or moving the springs in board, directly under the frame, like toyotas. Anyone have any input, good or bad, that would help me make up my mind???
    Thanks!
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I would not mount the springs under the frame due to the fact that the frame is not boxed. Mounting the springs on the bottom of the frame which is nothing more than "C" channel would put all the stress in the wrong location of the frame.
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Like he said Unless you BOX your Frame I wouldn't hang your springs under the frame, although if you did BOX your Frame and hang them that way you would get great FLEX!
    Bill
  4. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    i agree with all the above /forums/images/graemlins/thumb.gif
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I moved my springs in board and did box the frame where the springs mount. I think it is important when you box a section of the frame to fish mouth the ends of your boxing plates so the stress is relieved in a consistent manner. If not you will create a shear point. Mine are fish mouthed and bent in so they cross the lower web as the they taper down. I talked to some engineers that work where I do and they suggested this to be the best way. If you want I can post some pics for you.
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i would like to see some pics of the plate u used to box the frame w/.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm sure you've seen my opinion on frame boxing in other posts, so I won't say anything more than that I wouldn't box it. The stabilizing effect you need is better achieved via. a cross member rather than boxing. Also, my buddy Mat with the orange Ford has had his in boarded since around 1999 without boxing the frame. He's had no trouble and he beats it unmercifully...
