Rear spring perches from hell
Discussion in 'The Garage' started by Desert Rat, Jul 17, 2005.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Holy crap! Talk about your all time royal PITA. I pulled the rear Corp14 today to cut off the spring perches so I can rotate the axle and re-weld new ones on. I think these things may be the death of me. Nearly triple digits outside and I'm waging war with a grinder, cut off, and sawzall. So far after several hours I only have one whittled down to about 2/3rds gone. :mad: :doah: :angry1:
  2. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    You must have the ultra special edition top secret military perches...:haha: (other wise known as the cast perches)
    Rene
  3. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I'll say! I figured once I cut through the outer weld areas, they would pop off. NOT. They are solid through and through. I have blisters on blisters and my back hurts. I may have to have a long conversation with Mr. Daniels tonight..........
  4. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    You should have had that conversation with Mr. Daniels before attacking those perches...:D
    rene
  5. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Do you have a torch? Most efficient way to get perches off. I just cut as close as I dare and then grind 'er smooth.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i had the cast ones and i cut through the welds and beat them off with a BFH
    took me about 20 min for each one
  7. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I don't have a torch, what did you cut the welds with Surpip?
  8. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I used a 4" grinder and BFH and mine came off :burb:
  9. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    Mine were exactly how Desert Rat described his...and they SUCKED!!!! good luck...it will be worth it when it is done.
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    just a regular thin cutting wheel on a 4 1/2" grinder
    it takes about 3-4 cuts per side to get the weld all the way around, i just got it as close as i could without cutting the tube ,
    also i cut the perch in half across the hole for the spring pin, width wize
    came right off with the BFH :D
  11. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I feel your pain as I'm going through this as well with my van 14b, and I just got some metal in my eye from doing this. Yes I was wearing glasses, and safety goggles. I'm going to try doing it Surpip's way and see how that works.
  12. goldwing2000
    goldwing2000 Guest
    hehehehe... you said 'beat them off'. :haha:
    On a more somber note, I'm going to have to go through this, as well. The 14bff I just picked up has the cast perches and they've already been moved once because they were installed on a Jeep.
    I'm glad I have a torch.
    Now to find some 2.5" square tube to make the new ones out of...
    Anybody know how much you have to move the axle on a shackle flip?
