Rear Spring Pivots
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Donovan, Nov 14, 2000.
  1. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Okay guy I want to know if you guys would be interested in a new Product. They are called spring relieves. They are made by BC broncos and here is some picutres of them http://www.bcbroncos.com/suspension1.html. What I need from you guys is how thick is your rear springs are. I will let Chuck from BC Broncos know and he plans on making some sets up for Blazers if you guys want. These do lift the rear up 2" I believe. So let me know or Chuck and he can help you out. These things will help with your rear flex and you will not get as much frame flex either.
    Donovan
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Do you need to know how thick the whole spring pack is or just the individual leaves?
    90K5
  3. Donovan
    524
    Arvada, CO
    I want the thickness of the hole pack. He will try to get a good average of the springs out there and make the kits to fit everybody.
    Donovan
  4. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    just exactly what do they do?????i've not heard of them.....
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  5. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I don't know about the rest of you but the first thing that I think of is Ubolt failure[​IMG]!!
    Not much thread is able to stick out of the Ubolt nuts[​IMG]! Duno about the rest of you but I prefer to keep my axel inplace with the spring pack firmlly attached........
    .02c
    http://www.burt4x4.coloradok5.com
  7. Donovan
    524
    Arvada, CO
    If you use good you bolts you will not have any problems. I have seen them in action and they work awesome and I have not heard of any failure. If you guys trash you bushing out this will fix it. Why do you think you strip u-bolts out because of the pressure you have on the u-bolts, you are trying to twist the spring pack in the spring perch. You get read of this action with the pivots.
    Donovan
  8. CK5
    May 19, 1999
    21,623
    701
    CO
    What about extra body roll on the street? Would they allow extra movment from side to side on the street?
    5,000 Pounds of American Rolling Steel
  9. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    are they angled for the natural driveline angle, or would they come with the needed shims to return the driveline angle to stock?
    I have an overload spring that brings my spring pack to 3 inches, without that spring my pack is right at 2 inches.
    Dan
    I am also concerned about Steves point, body roll on the street.
    <font color=red>get involved with land issues or lose the land</font color=red>
  10. Donovan
    524
    Arvada, CO
    No you should not have extra movement side to side but yes you will have more body roll because you are taking out the swaybar effect of the leaf springs. He said that he doesn't notice more body roll but some customer have said they see more body roll than before. I guess if you like how they work but don't like the body roll on the street put a sway bar on it with disconnects. I will let you all know how the work when I get a set.
    Donovan
  11. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Hey hows it going.Hows that adapter going?When you get them tell me what you think.The two inchs of lift would let me use some stock springs.I don't think the short stick out on the bottom u-bolts would be an issue.Mine are cut about 1/4 past the nut anyways.Will thay be the same cost.
  12. Donovan
    524
    Arvada, CO
    Hey Dan, Yes I think that the price will be the same but I will talk to Chuck to be sure. I started machining on it but have not got the splines cut yet. I hope next week that will happen.
    Donovan
  13. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Donovan..email me when you get Chuck to make some sets, I'm very interested...makimberlin@hotmail.com
    White Knight
  14. Donovan
    524
    Arvada, CO
    Okay will do.
    Donovan
  15. mudfanatic
    Feb 18, 2000
    614
    Aloha, Oregon
    I wasn't asking about side to side movement, I was wondering about the driveline angles would they be built to keep the driveline angle right, or would they require shims and if so does the cost include shims?
    Dan
  16. Donovan
    524
    Arvada, CO
    No he makes them straight so you will have to get your own shims aleast maybe for the first couple sets. Then he will have a idea what people need for a shim and maybe he could supply it I don't know. When I get the first set I will figure out what I need and we can go from there.
    Donovan
  17. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    forgot too ask last time i have a 14 bolt rear the axle tubes are larger then a 10 or 12 bolt will he be making too fit the larger axle tube.If so i'm interested in a set as soon as he gets them done.
  18. Donovan
    524
    Arvada, CO
    Yes I told him to make them for 3.25 tubes. The large housing fords are already 3.25 so that should not be a problem.
    Donovan
  19. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    these are like the revolvers shackles that shawn speckler has, it is based on the same idea it looks like
  20. Donovan
    524
    Arvada, CO
    Well they are kinda but I think that they work better than a revolver shackle. That is just my opinion on that. I think it makes your suspension more fluid and not so stiff. Chuck thinks they work so well that he is Patenting them which is not cheap to do.
    Donovan
