rear spring question
Discussion in 'The Garage' started by chrisb420, Nov 28, 2004.
  1. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    hey everybody, the other day i found set of leaf springs in my grandfathers garage and i wanted to ask your opinions before i tried to install them in my truck. first off i have an 86 k5 with a 2.5" set of front lift springs and blocks in the rear. the springs i found are the heaviest springs i have ever handled they are 56" from eye to eye and they have 8 leafs plus an overload i believe they came from a 1975 1 ton pickup anyway i was going to try and put them in and see how much lift they gave but i wanted to ask if maybe this may be to big of spring for the truck i dont really care if it rides a little rough like over speed bumps but i was thinking maybe this would be to much stress on the frame any suggestions are appreciated /forums/images/graemlins/thinking.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If those are 56" springs, then your going to have to move your rear spring hanger back as your blazer has 52" springs.
  3. chrisb420
    Aug 6, 2004
    652
    Binghamton, NY
    would there be any benefits to moving it back or would it just make sense to buy a new set of 52's
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    the 56's will flex better and you have the option of extending the wheelbase 4" /forums/images/graemlins/thumb.gif
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    In my opinion, its a personal preference. 56's will be a little more flexy, but with the springs you described, I highly doubt that.
  6. chrisb420
    Aug 6, 2004
    652
    Binghamton, NY
    i dont know if the springs have any flex they barely budged when i stepped on them and i am 200 lbs. i bet each spring weighs 80-90 lbs.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    If you leave all 8 leafs in there they will be stiff as hell, are you wanting to do a shackle flip for 4" of lift? if so then remove every other leaf in the pack, will flex like mad /forums/images/graemlins/thumb.gif
  8. chrisb420
    Aug 6, 2004
    652
    Binghamton, NY
    if i do the shackle flip would i still need to move the hanger back, i was thinking that if i move the hanger wouldnt that also shift the rear axle out of position would the wheel stay in the wheel well, longer driveshafts ?????
