Rear Spring removal????
Discussion in 'The Garage' started by sled_dog, Nov 13, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    How the heck do you do this? I got the spring unbolted at the shackle but how do you ever get a wrench on the nut side of the front mount??
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    if its the same as my 85, and I remember correctly, you have to bring a a wrench almost straight down onto the nut from the inside of the frame. feel around, you'll find it. /forums/images/graemlins/grin.gif
    j
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    all my wrenches are longer than the space between my body and that bolt as far as I can see. Guess its try and lift the body off too, guess I'm doing my poly body mounts now as well.
  4. BIGDAN112686
    BIGDAN112686 1/2 ton status
    Nov 20, 2002
    112
    nc
    i had the same problem on teusday. if i remember correctly it was a 7/8's nut, and i just moved it from the ratchet end until the nut lined up with a wrench, then it fit and held perfectly, all you have to do is ratchet it.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I was trying that but it wasn't working out, will try some more.
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i have a 4" deep socket that i aquired from somewhere. thats what i used. still was not easy!!!
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I figured out how to do it, had to go from the bottom through hole on the underside of the frame. Got the springs out just got a problem with my new bushings.
