Rear spring swap/ pick-up springs on a sub
Discussion in '1936-Present Suburban' started by retroblazer, Mar 21, 2004.
  1. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    284
    158
    Gustine
    In my on going qwest to finish my straight axle conversion, I had decided to swap in a 14FF in the rear. I have 7" of lift in the front through the brackets and a set of Deaver 4" lift springs. In the rear, I started with one of Watson's ORD shackle flip kits and a set of Pro-Comp 3" lift springs. Turns out that the springs are only for a pickup. I didn't figure out why the spring was so long and so soft until after I had swapped the spring hangers side for side, so that the distance from the front pivot to the rear was extended 2" further. But then we confirmed that the pickup springs are 65" long and the Sub's are 60". I am determined to use these springs so I cut the front brackets off the frame with the intention of moving them 3" forward to make room for the spring. Has anybody done this one already? How many leaves do you have to add to a 65"1/2 ton pickup to equal a standard 60" Sub spring? Second, if you have to move the front spring hanger, did you back it up with a plate on the inside of the frame rail? <font color="blue"> </font>
  2. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    What year sub are you working on? 60" leaf springs /forums/images/graemlins/dunno.gif
    Most of the suburbans have 52" or 56" rear leaf springs.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There's a hint here:
    It's gotta be a '92 or newer. /forums/images/graemlins/wink.gif
  4. retroblazer
    Nov 30, 2003
    284
    158
    Gustine
    Sorry, yeah it's a 94', my earlier posts were in the IFS section.
