Rear springs bolt removal, any suggestions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5DRAGER, Dec 24, 2001.
  1. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I got my front done yesterday..6 inch Bds and does it looks great. But now I'm working on the back and these bolts won't budge, they won't even turn. I assume they are rusted to the bushing sleeve. Ive already soaked them in wd40 and heated them with a torch with no luck. Just figured I would pick everyones brain for something that I have'nt thought of before I get out the cutting touch. Thanks all and happy holidays!
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    6 feet of pipe on your rachet. one click at a time until it free's up enough to impact it. leave impact on for a couple min. to warm everything up from spinning that fast
    <font color=red>Let me at it I can break it</font color=red>
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I am assuming you got all new hardware so saving the bolts is not improtant. Don't waste your time trying to get the nuts off, torch or sazwall them. If they are rusted that bad, even if you get the nuts off, you won't be able to get the bolts out. Also, if you didn't buy greasable bushings, do it, one of the best investments you will ever make. We put on a 6" BDS lift three weeks ago and used all greasable bushings and the ride is awsome.
    Derf00
    1990 K5 Jimmy 350 Edelbrock Performer TBI, 6in BDS Lift, Dana 60, 4.56, Corp 14B Detriot, 16x10 AE 589's, 37x12.5 SSR
  4. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks hammer,tried that to just stripped my ratchet and almost broke my breaker bar. Glad to here about the ride quality Derf00, yes I got all new greaseables from ORD and ruining the springs isn't a problem either since I'm going with a shackle flip and 2.5 inch springs in the back. Wel I guess its out with the cutting torch. Thanks guys
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Bummer man! I have to do this soon, too, but I'm putting in junkyard stock replacements for now, and can't get the shackle off of them. Torch (for heating, not cutting yet), impact, breaker bar, none of it works. I haven't had the time to get on it lately either...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Welcome to America.
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    And if using the torch isn't an option, try a sawzall..............works.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  7. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    well looks like ill be in for a ruff ride. i used the bushings that came w/ my 8in superlift springs, eh im not expecting it to ride like a caddy anway and im not going through wat i went through installing those front springs again just for new bushings.
    phill
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Torch, sawzall, or a grinder with a cutting wheel on it. I tried the sawzall method and it worked but I found it a little faster with the grinder.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  9. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    I had a b*tch of a time doing mine also. What I did is cut the head and the threads off so it was flush with the bracket and then I bent the bracket or spread it apart. It was just enough to fish it out of there. You will have to cut it as close to the bracket as possible. That is all I can tell you.
    Donovan
    <a target="_blank" href=http://www.rustbucket.rockcrawler.com>www.rustbucket.rockcrawler.com</a>
    Got Leafs??
  10. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    When I put in my 14 bolt I rented a torch and cut all the bolts off. The bolts were old so its better to replace them with new ones.
    TORCH 'EM OFF!!
    74 Blazer
    Zepplin
    Check out my Blazer
    <a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
  11. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    I have gone through several sets of supercrap bushings due to rust death.
    IF the greaseables work and I doubt it, try it sooner rather then later.
    compare ID of spring eyes before $$$ing up
    eventually the bolt rusts to the sleeve and snaps.
    a fluted bolt or inner sleeve to allow grease to travel the length of the bolt/sleeve is what is needed.
    greasing poly seems pointless, it doesnt rust
  12. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks for all the replys everyone. And yes there off... used the cutting torch on them. Some I cut the bolts off and some just needed the extra heat from this torch rather than the small one. If everything else goes all right I'll have the shackle flip and rear springs in this weekend and the lift will be done. Then its time to sweet talk the wife for the tires and rims!!!!
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I just took off my spring bolts too. 4" breaker bar and my big rachet worked like a charm. I have snapped the heads right off bigger bolts with that setup...so one way or another, those bolts WERE coming off. ;)
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
