Rear springs fanning out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by The Loner, Aug 3, 2002.
  1. The Loner
    The Loner Registered Member
    Aug 1, 2002
    13
    Davis, Ca
    The bottom leaf on both rear packs has fanned out a bit. They hit the shock when articulating, resulting in an indention in each shock. I tried to straighten them out through the use of a BFH, but no luck. What do I need to do to straighten them out? Why are they not staying straight in the first place? TIA.--B
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I was told the center pin in the spring probably broke they Are 5$ at most offroad places.
  3. Yuba K5
    Yuba K5 Registered Member
    Jul 31, 2002
    31
    marysville ca
    mine did the same thing. i used a BFH to get it back in place. then put on some brackets i found at the parts house.they had a flat peice of steel and small flat u bolts. i put them on the front of the spring it also helped with pinion angle by pulling the overload tight against the spring pack
  4. Grim-Reaper
    7,385
    Atlanta
    Loosen the U-bolts. make sure the center pin isn't broken. with the u-bolts loose should be no problem to knock them back in line. This probably happend due to the U-bolt not being quite tight enought. Should be about 110ftlb on the u-bolts. Even with them full tight if you wheel it hard you may need to re alingn them from time to time.
  5. Grim-Reaper
    7,385
    Atlanta
    That also kills articulation when you clamp the springs down like that.
