Rear springs vs. Shackle Flip?
Discussion in 'OffRoad Design' started by JohnnyFresno, Jul 16, 2002.
  1. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    What are the differences between the two? Why is one better then the other? I plan on going with 6 inches and I was considering rear springs. Should I go with a flip and 2" springs instead? What all would I need to do for 6 inches of lift(Driveshaft, t-case ect?).
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    new rear springs that are arched for lift are naturally stiffer and will therefore allow less flex than the stock springs would. The shackle flip is a good way to keep way flat/flexy springs and get lift at the same time.
    AFA what you'd need to do for 6" of lift, if you had any amount of suspension travel at all, you'd need to lengthen your driveshafts or get new ones. Depending on the angles between tcase and axles, you may need to rotate the rear or drop the tcase. Really depends on to many factors for me to cover right now. You would also, of course, need something to restore the correct steering geometry. Raised steering block, drop drag link, pitman, x-over or whatever. At any rate, as far as the shafts/angles, I'd install the lift and see what kinda vibrations you get and adjust shafts/angles until it runs smooth. If its any consolation, I have been building up my rig for 2 years and the vibes STILL arent solved. /forums/images/icons/wink.gif Its gonna happen soon tho, I'm going with a np205 and HAD shaft in the rear... problem solved!
    J
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Shackle flips are cheaper....... /forums/images/icons/grin.gif
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Yes but he want to go 6"s. To do that he needs a 4" shackle flip plus either 2" blocks or springs. Or he can go with 6" springs. In this case the 6" springs may be cheaper. But I prefer the flips.
  5. JohnnyFresno
    Mar 24, 2002
    194
    Clovis, CA
    Thanks for the info guys.
    btw Jekbrown I read over your shackle flip install /forums/images/icons/smile.gif great job on that. was funny read as well /forums/images/icons/laugh.gif
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    thanks for the kudos on the webshots pics... i try to keep 'em informative while tossing in some comedy from time to time. /forums/images/icons/wink.gif I know when I am flipping through some online photos, I get bored after a while if there isnt some interesting text accompanying the pics. I have LOTS more pics and install text to put up... but I doubt I'll get to it before Blazer Bash...
    J
  7. wheelin72
    wheelin72 Registered Member
    Mar 6, 2002
    97
    Hanford, CA
    look into the zero rate add a leaf too.
