Rear Springs
Discussion in 'The Garage' started by cegusman, May 22, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Does anyone make 3" of 5" rear lift springs
  2. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    Companies like Alcan and National Spring will make any size lift spring you want. Not ideal but pretty common: you could also get 2" or 4" springs and add a 1" block, assuming you're talking about the rear springs.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Most springs are rated for p/u's...when you install them in a blazer (esp. w/ the top on) they will not give as much lift as they clame because the rear end of a blazer is heaver than a p/u. If you want 5" lift get 6" springs. If you want 3" lift get 4" springs. Even going 1" higher it still might sag in the rear.
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I don't have a hard top anymore
