rear springs
Discussion in 'The Garage' started by DieselBurb, Oct 25, 2002.
  1. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    In ya'll's opinion, what which would be better, add-a-leafs or the Helliwig style bolt-on-the-top helper springs. I have an 85 3/4 ton Suburban which has a droopy tail. Someone suggested to flip the rear shackle. What would that do for ride height and driveline angles? /forums/images/graemlins/burb.gif
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  3. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    The Shackle flip would give you too much lift. I have the zero rate spacer mentioned in the post above and they were pretty easy to install. I put them on new springs, but I suppose it will give you just the lift you need to get back to stock ride height in the rear. They give you two small, steel blocks that bolt on to your springs. They give you the new spring bolts.
    The only problem you may run into is the need for new U-bolts. I had to get new U-bolts to make the spacers fit. You can get U-bolts made-to-fit at a truck supply company. They bent them while I waited.
