rear springs
Discussion in 'The Garage' started by chevystepside, Dec 29, 2002.
  1. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    f150 rears or stock chevy 95 rears springs for best articulation. using shackle flip 4" on 1989 k5 full size jimmy
  2. FULLSIZE
    FULLSIZE Registered Member
    Aug 8, 2002
    76
    F-150's bend(kink) easy, but flex better. ask yourself, would you rather be stuck or broken? /forums/images/graemlins/wink.gif
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    do they bend because of axle wrap? just need a trac bar.
  4. FULLSIZE
    Aug 8, 2002
    76
    the main leafs are thin and bend when backing up and the tire wont pop over what your backing over. they also go flat easier than the GM leafs. if you had an add-a-leaf and clamped the second leaf to the main leaf near the hanger they'd probably last longer. just my experience and the rig was a jeep, not as heavy as a K5. /forums/images/graemlins/usaflag.gif
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    With a good trac bar, the 57's dont get all bent out of shape any more than anything else would. Without it, your asking for failure. The two failures I've seen so far have been a result of not clamping the packs after they were disassembled but enough axle wrap on any leaf pack with destroy them eventually. Especially if you run them backward from what I understand.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The 57's flex better then the 63's?
  7. FULLSIZE
    Aug 8, 2002
    76
    there softer in stock form. this is a loaded question to say the least. you can always add leafs to make them useful but you lose flex and you can remove leafs from the 63" springs to make them flex better but then you would have the wrap problem.
    it comes down to a few objectives. if you spin the 57's around long side forward and put them in the rear, you can in theory have a better departure angle. you'd have to bob the back of the truck/blazer alot to take full advantage of the shorter springs though.
    i bobbed my truck 10" and the 63" springs just barely stick out past the tailgate. just enough for a bumper. it just depends on what your goin for. /forums/images/graemlins/confused.gif
