rear sus ??
Discussion in 'The Garage' started by boggerless, Jan 29, 2005.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    ok i have a relatively thick spring pack in the rear. and the truck had a helper spring when i got the truck.when i got the lift it came with a helper spring that was supposed to be bolted in the spring pack. well we just put it under the old one and tightened it down.NOW the rear end is pulling itself down so that the diff is horizontal with the street.it made the drive shaft even shorter, anyway can i flip the new helper spring over and not loose any lift?? help:)
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    do you mean parellel with the road? So you have 0 degrees of pinion angle? The add a leafs I've seen were meant to be installed in the spring pack somewhere, not underneath. Did you install it under the overload spring?
  3. boggerless
    May 26, 2003
    22,728
    96
    yea, its under the spring pack, WITH a helper that was there when i got the truck.and yes paralel to the street,flat on it.can i just flip it over and use it like a block?i don't want the front higher than the rear. i'm going to get new rear springs this summer but until i want to drive it.and TJ (big83chevy4x4) is gonna make my drive shaft. and i want the right length. i even had to get new longer u bolt to tighten it down. with the extra helper the ones that came with the lift couldn't take the preasure. i have 7 spring leaves not counting the helpers. i think the guy that used to own it hauled a big trailer.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    got any pics of this, its hard to picture in my head.
  5. boggerless
    May 26, 2003
    22,728
    96
    picture a normal spring pack with an overload spring, than pic another overload spring under it.then picture me getting pissed cuz the u-bolts with the kit didn't have the nut's to hold it.:)
