Rear susp change
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Jan 24, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    If i change out from blocks to springs do i have to worry about anyhting wiht the axle or driveshaft angles or what not.? Just wondering.
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 35" BFG Muds, Series 40 delta flow 3" tips
    Coming Soon: Suspension Work, Eaton Posi, More Exhuast work.
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    you might need to add a shim or something but i doubt it,,the springs should already have the correct degree shim on them.. you could check the block's and see what the angle is and compare it to the one on the spring's .
    <font color=purple>ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]</font color=green>
