rear suspension angle thrust help!!
Discussion in 'The Garage' started by cosmic.charlie, Jun 12, 2003.
  1. cosmic.charlie
    cosmic.charlie Registered Member
    Jan 22, 2003
    13
    massachusetts
    need some info on angle thrust, just installed 2.5 inch lift on 87 jimmy, now have a 2 degree angle on rear axle. anyone know why and possibly know how to correct the angle!thanks.someone did suggest shackle bolt being too tight i did check and seems o.k.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What kind of lift?
    Blocks? Springs? Shackle flip? Add-a-Leaf?
  3. cosmic.charlie
    Jan 22, 2003
    13
    massachusetts
    superlift springs
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Did you put the springs in the right way? Some aftermarket springs do not have the center pin exactly in the center. The # on the spring goes to the front.
    Also you are suposed to tighten down all the bolts at ride height. Keep them loose (hand tight or just a bit more) till it is on the ground.
  5. cosmic.charlie
    Jan 22, 2003
    13
    massachusetts
    the springs came tagged with a sticker "front". if the center holes arent exactly in center then how could you correct it?and thanks for answering i will redo them myself this time. a friend of mine installed them for me as i work too much. he also has a blazer and lifted his no problem so i do trust his work, he's also stumped. so thanks again for your help
  6. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Are you talking about the pinion angle? By the way are you going to see the Dead in a few weeks? Im going on the 21st at the meadows.
  7. cosmic.charlie
    Jan 22, 2003
    13
    massachusetts
    no its the thrust angle the rear axle is cocked to the right .just an axample but if i measured from the left front wheel to the rear left wheel its 37 inches and measured from the right front to the right rear it would be say 36 inches not accurate measurments just an example when my truck goes down the road the body looks like its driving crooked also a lot of vibration.and no i will probably miss this show do to working too much. i do need a show though.you mean the other ones right.have you seen them yet?
  8. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    I saw them in Hartford last year and have seen Phil many times. They have actually changed there name to "THE DEAD". Make sure the pins from the springs are properly seated in the holes in the spring perches. Other than that the axle should be straight. You could also check to be sure that both springs are the same, maby they shipped the wrong ones.
  9. Grim-Reaper
    7,385
    Atlanta
    Try swaping sides on the springs. Also measure in a X from like points. Check not only the axle but the spring mounts.
  10. cosmic.charlie
    Jan 22, 2003
    13
    massachusetts
    yeah ill have to pull them off tomorrow im at work all day today.thanks, really i did not know they changed the name
  11. cosmic.charlie
    Jan 22, 2003
    13
    massachusetts
    gettin tickets for the june 22nd show @ tweeter thanks for the info happier days ahead
