Rear sway bar
Discussion in 'The Garage' started by 80blackgmc, Nov 27, 2004.
  1. 80blackgmc
    80blackgmc Registered Member
    Nov 21, 2004
    43
    Hey guys. Just curious, was there a rear sway bar option on the 1 ton trucks? I have an '80 with a 14 bolt ff diff, but got no rear sway bar. Was wondering if there was one, if I could get it from a boneyard (good luck fininding one) and use it...
    Thanks.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I dont think there was a factory one, but I saw (like 2 yrs ago) an aftermarket rear sway bar, but dont recall what series (1/2, 3/4, 1 ton) it was for.
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I know there was a stock sway bar for the GMC Camper Special dually. I saw a couple of them at the junk yard. Not sure about SRW, though...
  4. nvrenuf
    Jan 7, 2002
    13,075
    246
    Mobile, Al.
    There were sway bars on the 2wd duallies but not the 4wd's. I have seen a pre-81 2wd with a 14 bolt and a sway bar but I don't know if it was original. I guess it all amounts to what options were ordered on the truck. /forums/images/graemlins/dunno.gif
    I took one from a 2wd dually (with a D70HD) and put it on the 14 bolt in my crew cab, fit like a champ. /forums/images/graemlins/waytogo.gif
  5. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    My 76 Blazer had one when I bought it but it looks like an aftermarket put on by the PO. I swapped in a Corp14ff and I suppose I could put it back on if I wanted to.
  6. 80blackgmc
    Nov 21, 2004
    43
    How is it attached? Anyone got any pics? Wonder if something could be built using either the front bar, or one from another style truck or big car...
    Thanks guys.
  7. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I'll have to find it and see if I can take a pic. Might be a Hellwig.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I pulled a factory rear sway bar off a 2wd 1 ton utility bed truck and have yet to install it on my blazer.
