rear swaybar disconnect?
Discussion in 'OffRoad Design' started by Jonny-K5, May 27, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    Does anyone know of a disconnect the will work on the rear of my K5. ive got a hellwig swaybar back there with the standard bolt/spacer/bushing setup. i sure like pulling pins instead of turning wrenches.
  2. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    K-5's had a rear sway bar /forums/images/graemlins/confused.gif
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    No, Hellwig is an aftermarket company that makes sway bars for just about anything.
  4. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Oh..I was confused
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    make your own disconnects... heh
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You might be able to get with someone like JKS who builds a bunch of different kinds of disconnects to match up what you have with what they have. There's a good chance something will work.
  7. Confedneck
    Nov 1, 2002
    5,236
    just build your own that pin in /out or something... couldnt be that hard, put your mind to it
