rear t-case seal problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Jul 24, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    the seal where my driveline slides into the t-case seems to be leaking. what is this seal called and what is involved in changing it. just a seal puller or is it more difficult than that. thanks.
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    what t-case is it??
    241/208/203/205
    they should all pretty much be the same if you have a slip yoke. just pop it out, carefull not to damage anything. get the number off the seal and take it to your local parts store.
    if it's a fixed yoke you have to take the yoke out first.
    i usually put a very slight (paper thin) coat of silicon around the seal. it'll act as a lubricant as it goes in and sealer when it dries.
    ARQ.
  3. dyeager535
    26,976
    Not sure what happens on the other t-cases, but when my 205 t-case to tranny adapter seal failed, allowing the t-case to overfill, the seal started to leak.
    Make sure the t-case fluid level isn't too high before replacing a seal that may not be the real problem.
