Rear tire carrier
Discussion in 'The Garage' started by mouse, Dec 12, 2003.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I would like to put a spare tire carrier on the rear bumper, instead of in the blazer. Is there anyone who make a kit to do this? Would a bronco setup work from the junk yard?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    4x4 Iron makes a very nice rear bumper /forums/images/graemlins/thumb.gif The ones that bolt to the body are only good up to a 33" or so before it will start tearing up the body
  3. stu454
    stu454 1/2 ton status
    Sep 17, 2003
    129
    Corte Madera, CA
    Do a google search for 'kennesaw mountain bumper'. They have a great looking replacement bumper/spare tire mount that I'm drooling over. They run about $500, but look to be worth it.
  4. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Stu is your truck drowning in that picture?
    -Andrew /forums/images/graemlins/usaflag.gif
  5. big k5
    big k5 Registered Member
    Nov 19, 2003
    88
    Sautee Nacoochee,Georgia
    You may want to check out your local welding shop.I wanted to do the same thing ,but instead I had one made that goes in a draw tite reciever hitch.It ran me about $195,but I can easily remove it when i don't want it.I also run 39.5"s & it supports one just fine.one thing that I did not do & wished that i had tried is using a ROUND pipe the same diameter as the square hole in the reciever hitch.this way you could remove the locking pin & rotate the tire down easily. ???? maybe this helps ???
