rear trailing arm improvements?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 13lazer, Jun 20, 2006.
  1. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    115
    San Pedro, CA
    i have recently lowered the rear of my blazer by 2" with blocks. i didn't plan it but after upgrading to front disks i needed to level it out. it seems very unstable now during freeway runs. mostly while driving really fast and the road bends a little. the rear of the truck gets all squirly and it seems a little top heavy. what are my options concerning improving the performance of my rig? its a 2wd blazer with a coil spring rear. im running a set of 17" oem toyota sequoia alloy wheels. i want it to ride like my stang where i bumped up my springs from 400# to 600# and added all the sway bars, among alot more.
    how can i modify my rear suspension it improve handling
  2. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Did you replace all the bushings in the rear suspension? Aftermarket sway bar would also help. Are the shocks good? I would ditch the blocks and order some tailor made drop springs for a pickup. Also, boxing in and reinforcing the trailing arms to reduce flex and bending will help. Do some research on same year Chevelle and Malibu handling mods-pretty close to the same design suspension.
  3. 13lazer
    Dec 30, 2004
    115
    San Pedro, CA
    the blocks aren't a good idea? i thought they were the same as stock because the shock absorber mount position is not modified, and you keep your stock spring travel. good advice, i did try to swap the bushings. i couldn't budge those bolts with a 4 foot structural steel assembly sized torque wrench. i'm sure i can get them with the multiplier. i wonder if the chevelle trailing arms are the same as truck trailing arms? maybe i'll try to install that swaybar i bought from summit. i couldn't figure that one out at first so i chucked it.
    thanks, i'll post later when i dial it in.
