rear u bolts ?
Discussion in 'The Garage' started by marcusxcore, Sep 27, 2004.
  1. marcusxcore
    marcusxcore Newbie
    Sep 27, 2004
    4
    quick question any one know the exact amount of torque the rear u bolts should be torqued down on stock 10bolts and 4 inch springs..
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    its around 130ft/lbs
  3. marcusxcore
    marcusxcore Newbie
    Sep 27, 2004
    4
    thanks my rear end wouldnt stay in place when i jumped on the gas i knew it was my u bolts werent tight enough i torqued em down to 90 /forums/images/graemlins/doah.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Sounds like you sheared off the center pin. You need to replace that before you drive it even if the u-bolts are torqued. I replaced mine with socket head cap screws.
