Rear view mirrors are way loose
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cryptobiotic, Mar 12, 2003.
  1. cryptobiotic
    cryptobiotic Registered Member
    Dec 31, 2002
    53
    Utah
    My rearview mirrors on my doors are really loose, do i have to take the door panels off to tighten them, and is that hard to do??? /forums/images/graemlins/k5.gif
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    no take the chrome cover off the side and there is one bolt right in the middle that you have to tighten
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Depends which kind you have. I have the larger framed ones that bolt on at three points. I have to remove the door panels to tighten them. If they are rusted you will have some problems as mine are.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I have always just removed the door skins and tightened the mirrors from the inside. I am pretty sure that a 83 has the same mirrors as an 85
  5. dyeager535
    26,976
    The bolts are accessible after removing the cover from the outside. (small torx bit, T-15?)
    If the plastic "sleeve" is missing though, you may not be able to tighten it up. Don't overtighten, the bolts aren't threaded very well. If the sleeve is missing, make another one out of a bicycle tire tube or something similar, it has to "grab" the post, but still allow for some adjustment.
  6. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    These are all good ideas. I have had to do lots of repair to both side-view mirrors. Because they are extended towing mirrors, there is alot more leverage on the doors and mounts. Eventually, this lead to both sides cracking the door steel on each of the three mounting points. I fixed this by drilling out the the mirror bracket and the door. Then I installing bolts, nuts, and BIG washers inside the door. To hold the mirrors from swinging, I drilled out the clamps around the mirror arm and used nuts and bolts to get a real grip on it. Then I covered it all back up with the chrome cover. Sounds confusing, but it's worked great! Good Luck...
