Rear vs front axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snowtoy, Oct 31, 2002.
  1. snowtoy
    snowtoy Registered Member
    Mar 18, 2001
    30
    Norway
    I need some inner parts to my rear 10 bolt, can I take parts from my spare front 10 bolt???
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I think you're going to need to be more specific... </font color>
  3. snowtoy
    Mar 18, 2001
    30
    Norway
    Sorry, question is: Can I use pinion gear (not drive pinion) and side gear from a front 10 bolt?
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I guess, I don't think there is anything different except the carrier between 28 and 30 splines.
    But If it were me, I wouldn't use used gears except as a set ring and pinion.
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I think he's talking about the spider gears inside of the diff. You can use them, but if they are different spline counts then the side gear will not work, since that is the part that is splined for the axleshaft. </font color>
  6. snowtoy
    Mar 18, 2001
    30
    Norway
    Yes that's what I talking about, In a Toyota Hilux they call it pinion gear and side gear. Thanks folks.
  7. dyeager535
    26,982
    191
    You are right, GM calls them side and pinion gears as well.
