rear wheel lock up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by balazerjake86, Dec 6, 2002.
  1. balazerjake86
    balazerjake86 Registered Member
    Oct 30, 2002
    41
    clarksville,tn
    My 1986 blazer has a little problem with the passenger side wheel. I noticed that when i drive it it feels like the back is dragging and not really spinning very good. I put the truck in neutral and jacked it up and the right wheels spins fine but the right one(sitting inside the vechicle) does not spin properly. my dad said that it started to happen after he put the parking brake on. i talked to a friend and he said that there is an adjusting nut that i can move and it might solve the problem but are these drums self adjusting? any way how do i fix this prob and is there any way that the parking brake is just not disengaging if so how do i fix this thanks all
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Remove the tire that isn't spinning properly and take the drum off. You might have junk in there not allowing the shoes to return after braking.
    There is an adjustment screw that'll allow you to adjust the rear drum brakes, but you should definitely take the drum off 1st to see if you have a bigger problem than that. The adjustment screw can be turned through a slit in the backing plate, You might have a rubber plug in the slit that'll have to be removed.
    Thomas.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The adjusting nut looks like a star and is located near the bottom of the drum assembly.
    To see if they're self adjusting - (I think they are) - drive in reverse, and hit the brakes...they should adjust.
    I agree with the previous statement to take off the drum and at least take a look for obvious problems.
  4. I think that if you have the adjusting nut on backwards it'll cause this prob. Might want to check that.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I would agree with most here except you said that it started when he applied the ebrakes, that is usually a sign of the cable seizing, or dust and gunk in the brake system.
    First have someone press the ebrake while you look at the cable and see if it pulls out and then moves back when they release it. I fnot , you found your culprit, mine does that now and I just pull on it with my hand and it unlocks so I am not using it untill I change the cable.
    If it is working properly then take the drum off and clean the assembly, I use compressed air then brake parts cleaner.
