Rear Wheel Spacers??
Discussion in 'The Garage' started by backcountry, Sep 27, 2004.
  1. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    Does anyone use wheel spacers on their rear ends? I would like my rear end to equal my front track if possible or practical.
    Any suggestions both positive and negative?
    If so, any suggestions on witch ones to purchase?
    /forums/images/graemlins/peace.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Unsafe IMO.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    They arnt that bad if you have a 14bff.
  4. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
  5. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    yep, those are the ones I run. They kick azz. People say that you should check the nuts on them to make sure they are tight every time you take your wheels off... well, I have been for more than 3 years now and my torque wrench always just clicks. They haven't loosened up a single ft/lb, so far as I can tell, in 3 years. I keep checking them tho.
    IMO, they are only "unsafe" if you don't take the time to check them on occassion.... just like wheel lug nuts and the nuts on your u-bolts and stuff... check them frequently and you wont have any probs.
    Having the front/rear track equal is a very good thing IMO. Wider is better with respect to stability sure, but more importantly your front and read tires will follow the same lines when you're offroad. Back when I had different width axles, I used to get annoyed that I'd have my front tires going where I wanted them but when the rear tires would get to the same spot they would be slipping/sliding in/out of the ruts the front tires were running in.
    j
  6. backcountry
    May 27, 2004
    916
    Those spacers look very stout. My only concern would be my 12 bolt rear end. I only have 35" tires though. /forums/images/graemlins/dunno.gif
  7. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    There is absolutely noting unsafe about a quality wheel spacer less than a 1.5" or so—at least no more unsafe than any after market aluminum wheel. Of course like aluminum wheels you’ll wanna check your bolt torque periodically after the first several miles.
    I run 1.5" wheel spacers from Performance Wheel & Tire on my Jimmy originally with a 10b and 35s and now w/ a 14b and 38s. I personally can't stand the look of a narrower rear axle. Other than just looks though, I can't vouch for any noticeable difference in handing or off-road performance.
