Rear wheel spacers
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TONYP, Sep 6, 2002.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    just checking to see if anyone has dimensions and info on the rear wheel spacers for a 1972 K5. I would like to build them from a print and take my tires off once, without having to leave the truck up on block if I have to bule print it myself. Thanks guys and gails...............
  2. wheelin72
    wheelin72 Registered Member
    Mar 6, 2002
    97
    Hanford, CA
    Sorry i cant help you but along with putting extra stress on the axle its also going to make ur turning radius worse.
  3. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    6-Lug or 8-Lug?
    I've got them on mine in 8-lug. Turning radius is a non-issue.
  4. TONYP
    Aug 13, 2002
    2,116
    so cal
    I have the 6 lug wheels, and in one of the ColoradoK5 tests I've read that the spacers haven't been a problem with the extra load put on the axle.
  5. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Tony,
    You know the only problem with the spacers is that their cost can make it seem like a bad idea on a 6-lug axle. I bought mine from the same place in that Tech Article (performance wheel?) and the total was just over $200 for the spacers, nuts, and shipping. That's a lot of money to spend on a 12-Bolt axle, especially if you plan on swapping it out later on anyway.....
    Beyond that though, I love the look of my truck with the CORRECT rear wheel track. It solved some rubbing issues too.
  6. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    I used 2" per side on my stock Blazer. Check it out
